Hello everyone
Until now the file writer always produced a .edf file with data but since this morning an error appears and the file is empty.
[ INF ] At time 32.383 sec <Box algorithm::(0x00002884, 0x00004273) aka EDF Fi
le Writer> Writing the file, this may take a moment.
[WARNING] At time 32.383 sec <Box algorithm::(0x00002884, 0x00004273) aka EDF Fi
le Writer> edfclose_file: Could not close file [C:/EEG/record-[2017.12.13-03.31.
33].edf]
[ ERROR ] {Error description} : {Box algorithm <EDF File Writer> uninitializatio
n failed}, {Error type} : {ErrorType::Internal (code 2)}, {Error location} : {C:
\ovm\sdk\kernel\src\kernel\player\ovkCSimulatedBox.cpp::125}
I didn't change the location which worked perfectly until today. Anyone knows if this a bug or if im doing something wrong? Im using Openvibe 2.0.0
kind regards
EDF file writer suddenly doesn't work
Re: EDF file writer suddenly doesn't work
Hi, could it be possible some other application or even crashed designer has the file open? What if you change the path and/or name of the file? Does reboot change anything?
Cheers,
Jussi
Cheers,
Jussi
I am having the same issue Did you solve it?
Hello!
I have a similar problem:
[WARNING] At time 0.000 sec <Box algorithm::(0x00006601, 0x00002719) aka Generic stream reader> No stream candidate in file for output 4
[WARNING] At time 0.000 sec <Box algorithm::(0x0000328d, 0x00003daf) aka EDF File Writer> Could not open file [C:/Users/María Isabel Casso/Desktop/pp_edf]
[WARNING] At time 0.000 sec <Box algorithm::(0x0000328d, 0x00003daf) aka EDF File Writer> EDFLIB_NO_SUCH_FILE_OR_DIRECTORY: [ ERROR ] {Error description} : {Box algorithm <EDF File Writer> processInput function failed}, {Error type} : {ErrorType::Internal (code 2)}, {Error location} : {C:\ovm-m\sdk\kernel\src\kernel\player\ovkCSimulatedBox.cpp::231}
[ ERROR ] {Error description} : {Process failed for box with id (0x0000328d, 0x00003daf)}, {Error type} : {ErrorType::Internal (code 2)}, {Error location} : {C:\ovm-m\sdk\kernel\src\kernel\player\ovkCScheduler.cpp::746}
[ ERROR ] Scheduler loop failed.
[WARNING] At time 0.008 sec <Box algorithm::(0x0000328d, 0x00003daf) aka EDF File Writer> Exiting without writing a file (open failed or no signal header received).
the ov2edf scenario is in the documents folder. I have the same issue with the ov2gdf scenario.
I'm working with the 2.2.0 64bit version
Please could you help me find a solution to this problem?
Thank you for your time and help!
Hi,
THe only time I have seen this problem is because i haven't enough space in HDD.
But maybe :
I have you all (administrator) rights on this output file folder (here the desktop) ?
Maybe (but really maybe) can you run OpenviBE in admin mode (right click on designer.exe properties->compatibility check run as administrator).
Thibaut
But maybe :
Thibaut
Hello!
I changed the file's path to a different user (Public): C:\Users\Public\Documents\convert ...
Turns out the special character in the previous user name caused the problem.
All the converters work just fine now.
