It is currently Sun Jul 15, 2018 7:10 pm
 Post subject: Matlab Box Memory Leak
PostPosted: Mon Oct 09, 2017 12:33 pm
Hello guys,
I have a question concerning the matlab box. I use it to process my signal. But after a while OpenVibe always crashed. I have looked into it and found out, that the memory usage of OpenVibe increases extremely during the operation. I was using time-based-epoching before the box, and it seemed like all epochs were saved in memory?!
Now I am doing the epoching myself in the matlab box, so the memory usages increases slower. But still, after some hours also this would lead to a crash.
This can be also observed in the FFT-Matlab Tutorial.
My code in the simplest version producing the problem looks like this:
Code:
function box_out = adaptive_process(box_in)
for i = 1: OV_getNbPendingInputChunk(box_in,1)
    [box_in, start_time, end_time, matrix_data] = OV_popInputBuffer(box_in,1);
end
box_out = box_in;
end
Am I doing something wrong? Is there a solution for this?
Simon
PostPosted: Mon Oct 09, 2017 2:16 pm
Hello Simon, which openvibe version are you using and on what OS? What Matlab version? We can try to confirm and fix.
Edit: Indeed, it seems that OV1.3.0 Matlab box leaks memory pretty badly. Can you try this attached replacement and tell us if it works better for you? Its for Windows OV 1.3.0.
matlab-plugin-memory-leak-fix.zip [101.2 KiB]
Downloaded 40 times
PostPosted: Mon Oct 09, 2017 5:44 pm
Hey Jussi,
thanks for the very quick help!! I didn't have a lib folder anywhere in my OpenVibe directory so I put the lib folder from the zip-file just directly in the OpenVibe directory, is that correct?
On a quick try it seems like this fixed it, I'll do more testing and get back to you, if I run into more problems.
Thanks a lot,
Simon
PostPosted: Tue Oct 10, 2017 7:37 am
Great to hear that it works so far, and thanks a lot for the report. It seems a rather major bug, so I'm surprised no one reported it before. Maybe they use less data and/or have huge amount of RAM.
The lib/ content might indeed be unneeded runtime on Windows.
Don't hesitate to let us know if you encounter issues with it (or ov in general, of course).
