* operation in the simple DSP
kiyarash
Post by kiyarash »
assuming that the input to the simple DSP box is a matrix X and we write the expression X*X as the Equation.
does the * operation in the simple DSP box mean matrix multiplication or is it an element-wise multiplication?
Re: * operation in the simple DSP
Hi Kiyarash,
its an element-wise multiplication. All the operators (+,-,*,/) of Simple DSP are elementwise.
- If you need 'constant matrix * X', you can get this from the Spatial Filter box (the filter is the constant matrix).
- If you need matrix product 'X*Y' or 'X*X' for matrix chunks, this would need to be developed, afaik.
