I am having a terrible time getting a time-based epoch block to work. You may think that nothing could be simpler!
I have attached an image of my designer page the process is simple:
[*]read signal data
[*]Temporal filter (output shown on Signal display)
[*]Time based Epoching (1s, 0.5x) ( no output on the Signal Display)
If I put Stimulation based epoching block before the Time based epoching then it works, but only of course when the stimulation has been received.
Hmmmmmmmm.
Any help would be greatly appreciated.
Caitlin
Problems with Time Based Epoch
- Untitled.png (104.06 KiB) Viewed 2638 times
Re: Problems with Time Based Epoch
The attached scenario works just fine for me. How about for you? In your scenario, try isolating after which box the signal display stops working and reduce the scenario to the bare minimum.
Also, whats in your signal? If you replace the reader with a generator, does it work?
- test.xml
- (15.32 KiB) Downloaded 242 times
