OpenViBE forum
The OpenViBE community
It is currently Mon Oct 22, 2018 7:18 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Fri Apr 01, 2016 5:06 pm
Offline
Hello,
I've been recording some .ov data on openvibe, using EmotivEPOC on the P300-Speller-xDawn procedure.
However, when I try to use it on Scilab/Matlab, converting it to an .EDF file, I can visualise the raw data, but I cannot see when the stimulus are being sent. Where/how can I read the EDF file and know, on Scilab/Matlab, when the stimulus (target letter) was elicited?
(I need to know when the stimulus is shown to be able to recognise the raw data 300 ms after the stimulus).
Thank you in advance!
Top
 Profile
PostPosted: Fri Apr 29, 2016 8:55 am
Offline
Hello Artur,
the EDF Writer box apparently has a stimulation input, so in principle it should be able to write the stimulations to the .edf file. How well this feature has been implemented, we don't know. The box is a contribution. At a glance to the box source code it looks like the stimulations are written to the edf file as text format 'annotations'. Then there's the question how to get the annotations out on the reader side, which is a different question entirely.
Best,
Jussi
Top
 Profile
PostPosted: Thu Aug 11, 2016 9:36 pm
Offline
So, when trying to read those files on Matlab, I do have this column called "EDFAnnotations", but it does not show when the target letter was flashed during the test, and that is exactly what I need to know. Am I missunderstending the information on the column or this information is not inserted there? In this case, how can I get, on Matlab, when the target letter was flashed?
Thank you.
Top
 Profile
PostPosted: Thu Dec 15, 2016 11:35 am
Offline
If it doesnt work, you could try another format like gdf. Gdf readers are available via matlab package eeglab for example.
How did you produce the edf file?
Sorry for the late reply,
Jussi
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
