Dear all,
Is there any planning on adding the Filter Bank CSP algorithm to Openvibe?
It's really a necessary block to be added to the package.
Filter Bank CSP
Re: Filter Bank CSP
So far, we don't have feature selection yet in OpenViBE, but that is planned! When that would be available, you'll have everything needed to do FBCSP.
In the mean time, you can still use a filter bank and learn CSP filters for each band. If you don't extract too many filters, that still gives very good results.
I hope this helps,
Fabien
I hope this helps,
Fabien
Re: Filter Bank CSP
Thanks for your response.
How can I define a filter bank in Openvibe?
Re: Filter Bank CSP
There is no box to define a filter bank directly, but you can simply use multiple "temporal filter" boxes, each one designing one of the filter in the bank.
