Hi everyone,
I want to detrend my signal online adquired, but I'm really stuck. I've tried substracting a MA from the original data, but it didn't work.ç
Could you help me?
Thank you and regards.
Detrending the data
Re: Detrending the data
Well, I think I've achieve it.
Now, after many hours triying it, I have to re-join my epochs, I mean, concatenate all the epochs in a single one.
Any idea? Thank you.
I attach the scenario.
- PB_cal.xml
- (59.57 KiB) Downloaded 299 times
We used to have detrending functions in OpenViBE (first order and second order detrending - i.e., simply subtracting the value of one sample for that of the previous one).
But those detrending, as are moving average, as in fact a temporal filters. So the cleanest way of doing that would be by specifying coefficients of a temporal filter, or simply by using a high-pass filter to remove the trend (i.e., the low frequencies).
I hope this helps,
Fabien
I hope this helps,
Fabien
