I can not modify the P300 Magic Card Visualization Box
shelldream
Post by shelldream »
Hi
I downloaded the version 0.18.0-1. I found a problem.
Firstly I modified the paths of the card images in the P300 Magic Card Visualization Box and saved this modification. When I open this box again, these paths became the default values (${Path_Data}/plugins/simple-visualisation/p300-magic-card/zelda.png).
This phenomenon has not happened in the developer version of the openvibe ever on my PC.
:D :D
Re: I can not modify the P300 Magic Card Visualization Box
That is a problem some boxes have in the 0.18. As far as we know, it should have been solved in the git integration-1.0 branch and the next release (due soon).
If you need to use 0.18, you can edit the corresponding fields of the .xml with a text editor. That should work.
