Hey,
I am trying to send some signals using the analog VRPN box. I was wondering what is the data rate at which I can send signals? My generator is producing signals at 100 Hz and has 10 channels. Will the data transfer ok or will I have loss of data?
Thanks for the help.
VRPN data rate
VRPN data rate
Karthik
Karthik
Re: VRPN data rate
Hi karthiks,
Producing 10 values at 100Hz frequency seems ok to me !
I believe VRPN as some internal cyclic buffer so as long as you consume the data fast enough you won't have any problem.
L-
L-
