Sorry for dumb question.
Does Matlab box REALY present in Openvibe 0.12.0 Win32 distributive?
If it does. How it have been nemed and there can be found?
Thanks. For answers and REALY good programm
MATLAB box
Re: MATLAB box
In my case it is under Tools->Matlab filter. But if it is not there you will probably need to compile the package from the sources. More info on how to do that can be found here.
To compile the Matlab filter box, you will probably need to uncomment the following rule
in the win32-init_env_command.cmd script
Dieter
echo %OpenViBE_plugin_matlab% >> %OpenViBE_build_order%
Dieter
Re: MATLAB box
Thanks, Dieter
That's what I thought
But here was wrote
"The Matlab Filter box is now compiled by default and included in the release. This box is still unstable, but has been fully reworked in order to work on every machine, as long as Matlab (version 32bits) is installed."
http://openvibe.inria.fr/openvibe-0-12-0-released/
I hope not (make love) with compilation
SO LET'S GO COMPILE
So strange.
I so ..
[ INF ] Added 1 plugin object descriptor(s) from [../bin/OpenViBE-plugins-matlab-dynamic.dll]
But nothing comes at Tools section.
Yes!! I found solution in /share/openvibe.conf
var Designer_ShowUnstable - must be set - true
Probably , need to describe this in Release notes?
SO LET'S GO COMPILE
So strange.
I so ..
