Use of one box to trigger another
Hey,
I am trying to use a pattern generator box ( I wrote it) to give some output patters. I want to use an existing classifier as the start trigger for this box. For example, if the beta power goes above this level, trigger the start of box.
How can I do this?
Karthik
How can I do this?
Karthik
Karthik
Karthik
Re: Use of one box to trigger another
Hi !
Afterward, the trained classifier processor box is used in the online stage, and outputs the class selected. This class label can be used as a trigger afterward I guess.
If you simply need a box that outputs a "trigger" stimulation when a threshold is reached, I think you can write a simple box that does the job !
This box could be very close to what the Crop box does already.
Good job I guessI am trying to use a pattern generator box ( I wrote it) to give some output patters.
OpenViBE currently includes 2 classifier, LDA and SVM. They need to be trained on some features you extracted in a first acquisition stage.I want to use an existing classifier as the start trigger for this box. For example, if the beta power goes above this level, trigger the start of box.
Hi Laurent,
Also, what should I be coding in to my pattern box so that it only starts when the trigger is received? What is the OV_TypeId of the trigger? Streamed Matrix?
Karthik
So, how can I generate the trigger output? I mean to ask, what exactly in the coding docs should I be looking at?lbonnet wrote:OpenViBE currently includes 2 classifier, LDA and SVM. They need to be trained on some features you extracted in a first acquisition stage.I want to use an existing classifier as the start trigger for this box. For example, if the beta power goes above this level, trigger the start of box.
Karthik
hey,
any suggestions about the trigger coding?
Karthik
Karthik
As lbonnet suggests, if you first build a classifier that is able to discriminate between high and low beta power then the bias term in the classifier will function as your threshold. The label that is the output of the classifier is then simply a trigger for your box to activate. So you should connect the first output of the classifier processor box to the trigger input of your box. This should be of type Stimulations just as the first label output of the classifier box. In your box you should then check (probably in the process function of your box) if a certain StimulationId is received and consequently activate or start executing the code in your box.
To work well, you will probably need to adjust the bias of the classifier in order to have a low amount of false positives (otherwise it could be that you box is activated a lot).
If this is not the answer you are looking for, maybe you can specify more details about your application so that we can have a better view on what you are trying to accomplish.
Dieter
Dieter
Thank you for the help.
I am unable to understand the coding of the stimulation part. As suggested by Laurent, I have tried to modify the crop box, but the problem remains in how do I say that "if the value is higher than x, send this stimulation"?
I have gotten up to this but the output does not give stimulations (I used Stimulation listener for this). What am I doing wrong?
Any help is appreciated.
if(m_vDecoders[i]->isBufferReceived())
IMatrix* l_pMatrix = m_oSignalDecoder.getOutputMatrix();
float64* l_pBuffer = l_pMatrix->getBuffer();
if(*l_pBuffer > m_f64Threshold)
*l_pBuffer = this->getTypeManager().getEnumerationEntryValueFromName(OV_TypeId_Stimulation,"OVTK_StimulationId_Start");
m_vEncoders[i]->encodeBuffer(i);
Karthik
Karthik
I assume one of the encoders in your array m_vEncoders is a stimulation encoder? How is l_pBuffer then connected to the input of this stimulation encoder?
I looked at the code of the Clock stimulator and to generate stimulations I would expect the following code in your initialize method
Somewhere in the process function I would then expect at least the following lines of code
It could be that some more details should be added, the code of the Clock stimulator can probably help you with that.
Hopefully this helps you to progress?
Dieter Devlaminck
m_pStimulationEncoder=&this->getAlgorithmManager().getAlgorithm(this->getAlgorithmManager().createAlgorithm(OVP_GD_ClassId_Algorithm_StimulationStreamEncoder));
m_pStimulationEncoder->initialize();
//initializes the variable that will handle the stimulation set in which you will later save the information of your stimulation (time and label) and connects it to the input of the stimulation encoder. You now just have to fill in the necessary information of the stimulation (time and label)
TParameterHandler < IStimulationSet* > ip_pStimulationSet(m_pStimulationEncoder->getInputParameter(OVP_GD_Algorithm_StimulationStreamEncoder_InputParameterId_StimulationSet));
//requests the current time
uint64 l_ui64CurrentTime=getPlayerContext().getCurrentTime();
// the label of your stimulation, this is your code
m_ui64StimulationId=this->getTypeManager().getEnumerationEntryValueFromName(OV_TypeId_Stimulation,"OVTK_StimulationId_Start");
//append the stimulation to the set with the information (label and time) you have given above
ip_pStimulationSet->appendStimulation(m_ui64StimulationId, l_ui64CurrentTime, 0);
//now call the encoder to process those stimulations so they are sent to the output of your box and thus to the next box
m_pStimulationEncoder->process(OVP_GD_Algorithm_StimulationStreamEncoder_InputTriggerId_EncodeBuffer);
Dieter Devlaminck
Hey Dieter,
Thank you for the effort. The code that you have linked is done using the old way of coding in OpenViBE.
I was trying to use the Codec Toolkit to code since it is faster but seems like I should fall back to the older coding style.
Thanks again for the help.
Karthik
Karthik
Dear Karthiks,
Ok, I'm sorry, I'm still using the old way, anyway thanks for pointing this out. I took a look at the toolkit, but I still do not understand your code. Where exactly in your code do you set the StimulationSet with the necessary information and where do you connect it to the input of the encoder algorithm? You want to tell the encoder to encode the stimulation that you have saved in your variable l_pBuffer but how does it know this? A stimulation encoder does expect a StimulationSet no?
In my opinion you will still need to request the input of the encoder
and then insert your information (label and timing) in this object with the usual methods.
and then call
It should be something along those lines no? Maybe you could post the complete file?
Dieter
IStimulationSet* l_pStimulations = m_oStimEncoder.getInputStimulationSet();
setStimulationIdentifier (const OpenViBE::uint64 ui64StimulationIndex, const OpenViBE::uint64 ui64StimulationIdentifier)
setStimulationDate (const OpenViBE::uint64 ui64StimulationIndex, const OpenViBE::uint64 ui64StimulationDate)
m_oStimEncoder->encodeBuffer(i);
Dieter
Dear Dieter,
I think it may be easier and faster for me to just take a train to Ghent :p
So, the first idea worked out. I feel quite stupid for not realising it before -
But, the new problem now is that there is a continous stream of Stimulations even though the "if loop" is not satisfied. Any ideas for the solution?
Edit: For now, I have moved the in to the loop
I don't think that is a good solution so any help is appreciated.
OpenViBE::Kernel::TParameterHandler <IStimulationSet*> l_oStimulationSet = m_oStimEncoder.getInputStimulationSet();
uint64 l_ui64CurrentTime = getPlayerContext().getCurrentTime();
uint64 l_ui32Stimulationflag = this->getTypeManager().getEnumerationEntryValueFromName(OV_TypeId_Stimulation,"OVTK_StimulationId_Start");
l_oStimulationSet->appendStimulation(l_ui32Stimulationflag, l_ui64CurrentTime,0);
Karthik
Karthik
Hehe, true. What research are you doing or which project are you involved in? I tried to find something on the ULB site related to brain-related research, but could not immediately find anything.karthiks wrote:Dear Dieter,
Ok, great to see that you already managed to get some stimulations at the output. Concerning the new problem, the following two ideas just came to my mind (however I'm not an expert so it's just an idea): if it still outputs stimulations while it is not in the if loop then this means the stimulations of the previous call are still saved in the input of the encoder which your variable l_oStimulationSet is pointing to. Maybe it helps to first set the stimulation count to zero each time the process function is called?karthiks wrote:So, the first idea worked out. I feel quite stupid for not realising it before -
But, the new problem now is that there is a continous stream of Stimulations even though the "if loop" is not satisfied. Any ideas for the solution?Code: Select all
if(m_vDecoders[i]->isBufferReceived()) { OpenViBE::Kernel::TParameterHandler <IStimulationSet*> l_oStimulationSet = m_oStimEncoder.getInputStimulationSet(); uint64 l_ui64CurrentTime = getPlayerContext().getCurrentTime(); IMatrix* l_pMatrix = m_oSignalDecoder.getOutputMatrix(); float64* l_pBuffer = l_pMatrix->getBuffer(); if(*l_pBuffer > m_f64Threshold) { uint64 l_ui32Stimulationflag = this->getTypeManager().getEnumerationEntryValueFromName(OV_TypeId_Stimulation,"OVTK_StimulationId_Start"); l_oStimulationSet->appendStimulation(l_ui32Stimulationflag, l_ui64CurrentTime,0); } m_vEncoders[i]->encodeBuffer(i); }
l_oStimulationSet->setStimulationCount(0);
l_rDynamicBoxContext.markOutputAsReadyToSend(...)
Dieter
This worked perfectlyddvlamin wrote: Ok, great to see that you already managed to get some stimulations at the output. Concerning the new problem, the following two ideas just came to my mind (however I'm not an expert so it's just an idea): if it still outputs stimulations while it is not in the if loop then this means the stimulations of the previous call are still saved in the input of the encoder which your variable l_oStimulationSet is pointing to. Maybe it helps to first set the stimulation count to zero each time the process function is called?
This was already implementedddvlamin wrote: A second idea, do you mark each chunk as "ready to send" with
as this sets the chunk size to zero again till the next call to process?Code: Select all
I work with Prof. Cheron http://www.cheron.be/ on MINDWALKER https://mindwalker-project.eu/ddvlamin wrote:
Karthik
Karthik
Ok, glad it works.
Shame on me, I didn't know of this project, it is missing on my list of European BCI projects It seems a quite large and ambitious project. Do you already have a working brain-controlled exoskeleton or is this planned as a demo for the end of the project?
I assume you are also working with the ANT amplifiers as Dr. Zanow is a partner in this project?
Dieter
Dieter
Heh, shame on us that we are not so knownddvlamin wrote:Ok, glad it works.
Dieter
We are progressing towards the exoskeleton and most probably at the end of project, there should be a demo.
Yea, we are working with ANT amplifiers. We also have a Emotiv cap but it is not so useful for motor imagery tasks.
Karthik
Karthik
Hey Dieter,
One last question, if we have an algorithm that generates our results at different points in the algorithm. for ex. we need x, y and z but they are calculated at different points in the algorithm. How do we pass them as output?
I am using a StreamedMatrixEncoder here.
Karthik
Karthik
