Hello, i just subscribed to the forum.
I've been starting my PhD in Würzburg, Germany and successfuly translated a BCI2000 Cursor Task feedback paradigm to an OpenViBE scenario with all the proper stimulations.
First I used Olivier Rochelle BCI2000 translation box that works pretty well. Its output has 2 signal : 1 for EEG signals, and 1 corresponding to the variable used (TargetCode, Feedback, PositionY...).
I translated these signals by a box I created, that i called Signal Trigger, that allows to send specific stimulations when signal has a specific value.
Then i had problems to add start and end_of_session stimulations in my signal, so I created a begin- and end stimulation bounding box (adding stimulations when signal input recieves headers, and end chunk).
I noticed that in Signal Concatenation box (thanks for previous changes btw), the headers and end chunk were not removed between parts of the concatenated signal.
I would like to know if it's normal or not.
I also noticed something with the stream switch : is it normal that it can switch almost every kind of signal but not stimulations ?
I hope it could help you to improve these boxes.
Loic
SignalConcatenation and StreamSwitch
Re: SignalConcatenation and StreamSwitch
Hi Loic !
Thanks for the feedback...
We already discussed this face to face at BCI workshop in Graz, but I guess the answer can interest more people around
We will be glad to integrate this box as soon as it's totally stable. From what I recently heard it's on its way to release
I will investigate this asap.
It's not a huge job to add stimulation stream as a possible input/output I guess
If you or someone else is willing to contribute a patch, I will gladly integrate it!
Good !First I used Olivier Rochelle BCI2000 translation box that works pretty well.
I guess it's not normal, as one header should be enough (the box checks for coherency between all headers before starting the concatenation).I noticed that in Signal Concatenation box (thanks for previous changes btw), the headers and end chunk were not removed between parts of the concatenated signal.
The stream switch has been made for all kind of streamed matrices (ie. streamed matrices and its derivated; signal, feature vectr, etc.).I also noticed something with the stream switch : is it normal that it can switch almost every kind of signal but not stimulations ?
Thanks for the answer lbonnet,
Once these problems are fixed I will make scenarios that are appropriate and which can be shared.
Best regards
Loic
Best regards
Loic
I just patched the signal concatenation box.
The Header and End duplication problem should be solved.
Now the box has a third output (stims) that sends the stimulation OVTK_StimulationId_EndOfFile when the concatenation is finished.
With a Player Controller you can now easily script your concatenations.
I didn't investigate the Stream Switch so far, please let me know if you already did some modifications
I could send you the boxes and scenario from BCI2000 recordings to OpenViBE translation,
but the bci2000 reading box is stored on OpenViBE-Cortex repository.
So that make no sense at all if I send this now.
If you get it from Nancy, then I will send you a nice christmas present
Happy Christmas !
Happy Christmas !
Thanks Loic!
I manage to get the BCI2000 File Reader from INRIA Nancy. It's available temporary in a branch (file-io/branches/wip-bci2000).
It's an official candidate for integration for the next release (this month).
If it passes the tests it's ok for us.
Happy new year!
Happy new year!
