2D topographic warning
shelldream
Post by shelldream »
Hi, :D
I met a problem nowadays.
I substituted the Acquisition Server for the Generic Reader in the scenario "topographic-map " ,so that I could read my own data.The number of channels is 31.But,when the scenario was played,here came many same warnings:"Spline coeffients computation failed (sspfa25)". Then I debuged this scenario to find the error. I found that in the function "sspfa",when variable "k" was 2,the *ap was approximately 0,and then when k was 1,*info was 25 ,and then this warning occurred.
I didn't know if I express myself clearly. :P I want to know the function of SSpfa and what should I do to avoid this warning.Is something wrong with my data?
Best
Shelldream :)
