I'm wondering if anyone is working on a box which would enable Fast Fourier Transform, which I think would be better for extracting frequency components from the EEG measured for Neurofeedback application.
Thanks!
Will
Fast Fourier Transform Box
Re: Fast Fourier Transform Box
Hi Will !
In fact, the Spectral Analysis - GPL box is using a FFT.
(under "Signal Processing/Filtering/Spectral Analysis")
I just saw it was not mentionned in the description of the box. I fix this oversight
