XML stimulation scenario Player and sequence of target
MRichard
Post by MRichard »
Hello:
I'm trying to put a specific sequence of "Target" like "MIGUEL" but I can't do it.
So, How do I do?
Thanks a lot
Miguel.
Re: XML stimulation scenario Player and sequence of target
Dear MRichard,
this box seems buggy. This has been discussed in another thread, check viewtopic.php?t=241 for details.
Tell me if that's ok for you.
For your information, the Lua box is terminated and works like a charm on Linux... I still have to tune a couple of things to get it working on Windows.
MRichard
Post by MRichard »
I'm trying build but have a lot of error.
What version of Lua and Boost you use?
Dear MRichard,
as you probably noticed when you svn updated the sources, I have been taking care that this box does not compile without changing the sources (see the #if 0 / #endif pairs). This is for a reason. As I told you in my previous post,
Now if you still want to compile the box before I finish its integration, I used Lua 5.1.4 on Linux (you can install it with the linux-install_dependencies script but it is not yet included with windows dependencies) and Boost.Thread 0.22 (which is usually installed on Linux but is hard to get as precompiled for Windows).
Don't expect support on this until I have finished the integration / documentation.
MRichard
Post by MRichard »
Dear Yann
I see the "magic"
if 0
Don't worry, I have knowledge of c++. I'm developer with QT in Linux ;)
Thanks for you help.
Miguel.
Dear Mrichard,
Keep us posted about your advances.
