Hello,
In box algorithms, I don't find the boxes, 2D visualisation and 3D visualisation like in the first tutoriel. I don't find also algorithms box.
I have download the latest version of openvibe.
Can you please help me?
Thanks,
BOX ALGORITHMS AND ALGORITHMS
Re: BOX ALGORITHMS AND ALGORITHMS
EDIT: from mails to forum posts, so everyone can follow the discussion.
If you're running on windows, it should be on the path "C:\Documents and Settings\userName\openvibe.conf"
I don't know if on Vista this path is the same, but here is a way to be sure:
In the designer main window, click on Edit/Preferences. You can now visualize all variables your openvibe is using.
On of them is CustomConfigurationWindows. The expanded token value column gives you the full path to the configuration file.
Go in that file (or create it in the right path if you need) and add the following line:
You should see the "algorithms" list in the designer.
Regards,
Laurent-
To see the list of algorithm in the designer, you have to edit your configuration file.From fleur :
OS : windows Vista
OpenViBE: installer 0.4.0
Code: Select all
Designer_ShowAlgorithms = true
Regards,
Laurent-
Be sure to have a line feed (press "enter" ) at the end of the file openvibe.conf. If the last line of the configuration file is missing a line feed, this last line is not read by the designer. (I just tried this out).Quoting fleur:
Thanks
I created a text file "openvibe.conf" in the directory indicated by the software, and I added the missing line, but it does not work when I restart openvibe.
Regards,
Laurent
