First of all, I'm very happy with the python box in OpenViBE. I think it will make the life of some researchers a bit easier.
For some external experiments I was asked to create a display that shows the target and non-target ERP's in a superimposed fashion, instead of using OpenViBE's display box showing the two potentials next to each other (making it hard to compare the two waveforms).
To this end I wrote a small python script which uses the matplotlib package to make matlab like plots. When I execute a simple scenario the first time, it plots the curves well, but the second time I run the scenario within the same instance of OpenVIBE, it seems to crash given this exception:
OpenViBE-designer-dynamic: /builddir/build/BUILD/Python-2.7/Modules/gcmodule.c:326: visit_decref: Assertion `gc->gc.gc_refs != 0' failed.
Program received signal SIGABRT, Aborted.
0x00000038850330c5 in raise () from /lib64/libc.so.6
(gdb) backtrace
#0 0x00000038850330c5 in raise () from /lib64/libc.so.6
#1 0x0000003885034a76 in abort () from /lib64/libc.so.6
#2 0x000000388502b905 in __assert_fail () from /lib64/libc.so.6
#3 0x00000038a2719d8e in ?? () from /usr/lib64/libpython2.7.so.1.0
#4 0x00000038a269da45 in ?? () from /usr/lib64/libpython2.7.so.1.0
#5 0x00000038a271a497 in ?? () from /usr/lib64/libpython2.7.so.1.0
#6 0x00000038a271af09 in ?? () from /usr/lib64/libpython2.7.so.1.0
#7 0x00000038a26e965b in PyEval_EvalFrameEx () from /usr/lib64/libpython2.7.so.1.0
#8 0x00000038a26ea71d in PyEval_EvalFrameEx () from /usr/lib64/libpython2.7.so.1.0
#9 0x00000038a26eb04d in PyEval_EvalCodeEx () from /usr/lib64/libpython2.7.so.1.0
#10 0x00000038a26e963a in PyEval_EvalFrameEx () from /usr/lib64/libpython2.7.so.1.0
#11 0x00000038a26ea71d in PyEval_EvalFrameEx () from /usr/lib64/libpython2.7.so.1.0
#12 0x00000038a26eb04d in PyEval_EvalCodeEx () from /usr/lib64/libpython2.7.so.1.0
#13 0x00000038a2671c62 in ?? () from /usr/lib64/libpython2.7.so.1.0
#14 0x00000038a2648fc3 in PyObject_Call () from /usr/lib64/libpython2.7.so.1.0
#15 0x00000038a265a65f in ?? () from /usr/lib64/libpython2.7.so.1.0
#16 0x00000038a2648fc3 in PyObject_Call () from /usr/lib64/libpython2.7.so.1.0
#17 0x00000038a26e3a87 in PyEval_CallObjectWithKeywords () from /usr/lib64/libpython2.7.so.1.0
#18 0x00007fffedaf9d92 in OpenViBEPlugins::Python::CBoxAlgorithmPython::uninitialize (this=0x244aeb0)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-plugins/python/trunc/src/ovpCBoxAlgorithmPython.cpp:802
#19 0x00007ffff580d664 in OpenViBEToolkit::TBoxAlgorithm<OpenViBE::Plugins::IBoxAlgorithm>::uninitialize (this=0x244af48, rBoxAlgorithmContext=<value optimized out>)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-toolkit/trunc/include/openvibe-toolkit/box-algorithms/ovtkTBoxAlgorithm.h:37
#20 0x00007ffff70219d1 in OpenViBE::Kernel::CSimulatedBox::uninitialize (this=0x2503690)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-kernel-omk/trunc/src/openvibe-kernel/kernel/player/ovkCSimulatedBox.cpp:789
#21 0x00007ffff6ff2071 in OpenViBE::Kernel::CScheduler::uninitialize (this=0x25bfe30)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-kernel-omk/trunc/src/openvibe-kernel/kernel/player/ovkCScheduler.cpp:285
#22 0x00007ffff7015f28 in OpenViBE::Kernel::CPlayer::uninitialize (this=0x25bfdc0)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-kernel-omk/trunc/src/openvibe-kernel/kernel/player/ovkCPlayer.cpp:112
#23 0x000000000046707a in OpenViBEDesigner::CApplication::releasePlayer (this=0x7fffffffb400)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-applications/designer/trunc/src/ovdCApplication.cpp:1376
#24 0x00000000004671d9 in OpenViBEDesigner::CApplication::stopScenarioCB (this=0x7fffffffb400)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-applications/designer/trunc/src/ovdCApplication.cpp:1400
#25 0x0000000000460a15 in (anonymous namespace)::stop_scenario_cb (pButton=0xa5f1a0, pUserData=0x7fffffffb400)
at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-applications/designer/trunc/src/ovdCApplication.cpp:172
#26 0x0000003888c0e03e in g_closure_invoke () from /lib64/libgobject-2.0.so.0
#27 0x0000003888c1ee87 in ?? () from /lib64/libgobject-2.0.so.0
#28 0x0000003888c287b5 in g_signal_emit_valist () from /lib64/libgobject-2.0.so.0
#29 0x0000003888c28b6d in g_signal_emit_by_name () from /lib64/libgobject-2.0.so.0
#30 0x0000003888c0e03e in g_closure_invoke () from /lib64/libgobject-2.0.so.0
#31 0x0000003888c1ee87 in ?? () from /lib64/libgobject-2.0.so.0
#32 0x0000003888c287b5 in g_signal_emit_valist () from /lib64/libgobject-2.0.so.0
#33 0x0000003888c28983 in g_signal_emit () from /lib64/libgobject-2.0.so.0
#34 0x0000003369a90a85 in ?? () from /usr/lib64/libgtk-x11-2.0.so.0
#35 0x0000003888c0e03e in g_closure_invoke () from /lib64/libgobject-2.0.so.0
#36 0x0000003888c1e64c in ?? () from /lib64/libgobject-2.0.so.0
#37 0x0000003888c287b5 in g_signal_emit_valist () from /lib64/libgobject-2.0.so.0
#38 0x0000003888c28983 in g_signal_emit () from /lib64/libgobject-2.0.so.0
#39 0x0000003369a8f527 in ?? () from /usr/lib64/libgtk-x11-2.0.so.0
#40 0x0000003369b4e223 in ?? () from /usr/lib64/libgtk-x11-2.0.so.0
#41 0x0000003888c0e03e in g_closure_invoke () from /lib64/libgobject-2.0.so.0
#42 0x0000003888c1ec98 in ?? () from /lib64/libgobject-2.0.so.0
---Type <return> to continue, or q <return> to quit---
#43 0x0000003888c28555 in g_signal_emit_valist () from /lib64/libgobject-2.0.so.0
#44 0x0000003888c28983 in g_signal_emit () from /lib64/libgobject-2.0.so.0
#45 0x0000003369c85aef in ?? () from /usr/lib64/libgtk-x11-2.0.so.0
#46 0x0000003369b4bd33 in gtk_propagate_event () from /usr/lib64/libgtk-x11-2.0.so.0
#47 0x0000003369b4c103 in gtk_main_do_event () from /usr/lib64/libgtk-x11-2.0.so.0
#48 0x000000336a261a8c in ?? () from /usr/lib64/libgdk-x11-2.0.so.0
#49 0x0000003886c41e33 in g_main_context_dispatch () from /lib64/libglib-2.0.so.0
#50 0x0000003886c42610 in ?? () from /lib64/libglib-2.0.so.0
#51 0x0000003886c42c82 in g_main_loop_run () from /lib64/libglib-2.0.so.0
#52 0x0000003369b4b0b7 in gtk_main () from /usr/lib64/libgtk-x11-2.0.so.0
#53 0x000000000047d243 in go (argc=1, argv=0x7fffffffba48) at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-applications/designer/trunc/src/ovd_main.cpp:567
#54 0x000000000047d5aa in main (argc=1, argv=0x7fffffffba48) at /user/ddevlami/nas/home/openvibe_linux/trunk/openvibe-applications/designer/trunc/src/ovd_main.cpp:596
import numpy
import matplotlib.figure as fig
import matplotlib.pyplot as pyplot
class MyOVBox(OVBox):
def __init__(self):
OVBox.__init__(self)
self.signalHeader = None
def initialize(self):
pyplot.ion() #nasty trick, if not in interactive mode python blocks when drawing (although it shouldn't)
def uninitialize(self):
pyplot.close() #close the figure
def process(self):
for inputIndex in range( len(self.input) ):
for chunkIndex in range( len(self.input[inputIndex]) ):
if(type(self.input[inputIndex][chunkIndex]) == OVSignalHeader):
self.signalHeader = self.input[inputIndex].pop()
self.data = numpy.zeros((2,self.signalHeader.dimensionSizes[1]))
elif(type(self.input[inputIndex][chunkIndex]) == OVSignalBuffer):
pyplot.cla() #clear the axes so that at any given time only two curves are shown
chunk = self.input[inputIndex].pop()
self.data[inputIndex,:] = numpy.array(chunk).reshape(tuple(self.signalHeader.dimensionSizes))
x = numpy.arange(0,self.signalHeader.dimensionSizes[1],1)
self.lines = [None] * len(self.input)
self.lines[:] = pyplot.plot(x, self.data.transpose().tolist(), linewidth=1.0) #update line plots
pyplot.draw()
elif(type(self.input[inputIndex][chunkIndex]) == OVSignalEnd):
box = MyOVBox()
Dieter Devlaminck
