error when reading GDF file
KJeffrey
Post by KJeffrey »
I am trying to read in a GDF file and use it as input to a scenario that works fine with OpenViBE EEG recordings. I can display the contents of this GDF file in a simple scenario with the Signal Display box, but when I try to substitute it into my main scenario I get this:
[ ERROR ] Exception caught in box
[ ERROR ] [name:Bu S1 R1]
[ ERROR ] [class identifier:(0x00006a81, 0x0000610e)]
[ ERROR ] [hint: Box processing]
[ ERROR ] [cause:bad allocation]
[ ERROR ] {Error description} : {Caught exception: bad allocation}, {Error type} : {Kernel::ErrorType::ExceptionCaught (code 4)}, {Error location} : {E:\ovm-m\sdk\kernel\src\kernel\player\ovkCScheduler.cpp::634}
[ ERROR ] Scheduler loop failed.
A copy of the scenario is attached.
-Jeff
smok_clas_svm.xml
(44.5 KiB) Downloaded 177 times
