error from EOG Denoising Calib
KJeffrey
Post by KJeffrey »
Hi support,
I tried the EOG and got this result. I cannot imagine why it failed to open the cfg file.
-Jeff
test EOG denoise 2023-07-07_16-40-33.png (9.52 KiB) Viewed 19865 times
[ ERROR ] At time 0.000 sec <Box algorithm::(0x00000a67, 0x00003496) aka EOG Denoising Calibration> Opening [b-Matrix-EEG.cfg] for writing failed
[ ERROR ] {Error description} : {Box algorithm <EOG Denoising Calibration> initialization failed}, {Error type} : {Kernel::ErrorType::Internal (code 2)}, {Error location} : {E:\ovm-m\sdk\kernel\src\kernel\player\ovkCSimulatedBox.cpp::70}
[ ERROR ] {Error description} : {Failed to initialize player}, {Error type} : {Kernel::ErrorType::Internal (code 2)}, {Error location} : {E:\ovm-m\sdk\kernel\src\kernel\player\ovkCPlayer.cpp::153}
[ ERROR ] The initialization of player failed. Check the above log messages to get the issue.
