Help / advice needed for PLV (Hilbert, connectivity measure, ...)
skan
Post by skan »
I'm a complete noob regarding all things EEG and I just started doing some research and experimenting, so please forgive me if I tend to mess things up a bit...
I'm working on an art project where I need to track a piano player EEG in real time and use the data to generate projected visuals. The main setup is based on a Muse2 headband connected to an acqusition server through LSL (via BlueMuse).
I already managed to isolate alpha, beta, delta, theta and gamma bands and get the usual ratios in order to process vigilance, workload, etc...
I wanted to make a little step further and process a "meditation" state. According to various papers, I need to consider instantaneous phase locking value between front and rear parts of the brain in alpha+beta bands (7-28Hz).
I read the docs, but I cannot understand how connectivity measure box works, it keeps on reporting errors, hanging or crashing the Designer app.
F.I. the following workflow crashes badly.
Any help is appreciated, thanks!
Re: Help / advice needed for PLV (Hilbert, connectivity measure, ...)
Post by Thomas »
Yes we are aware of issues with the connectivity measure box. Unfortunately we do not have a fix at the moment.
We are currently working on this box and should be able to provide a stable version in a future release.
Although the release containing the fix will not be before 3 to 6 months, the fix should be available at some point on the development branch of our repository "extras".
You can keep an eye at the list of commits here: https://gitlab.inria.fr/openvibe/extras ... evelopment.
Feel free to ping us again in some time for news.
skan
Post by skan »
Thanks for the info! The project won't be ready before late summer 2021 anyway, so I might catch the update before that! ;)
