LSL export (Gipsa)
Harvey666
LSL export (Gipsa)
Post by Harvey666 »
I tried to send out signals from Open-vibe Designer to Python for Data Analysis using Pylsl.
But I got "The stream named 'OpenViBE Stream' could not be recovered automatically if its provider crashed because it does not specify a unique data source ID."
I am not sure how to use the LSL export(Gipsa) box.
Many thanks,
Harvey
Re: LSL export (Gipsa)
I have not yet had the time to look at the LSL protocol or how it is relayed to OpenViBE. You can see directly in the source code if you are used to the LSL protocol you should understand what is sent.
