Hi,
I want to use two Beep box in "erp-2-record-signal .xml" . One for short beep another for long beep . How can I change the beep tone ?
Rafia
Multiple beep box
Multiple beep box
- Attachments
- Capture.JPG (96.02 KiB) Viewed 10171 times
Re: Multiple beep box
Hi,
You can use an other beep file. Or activate the loop option if your initial beep file is "loopable" and you launch a stop stimulation to desactivate the sound.
Thibaut
Thibaut
From where and how I can get/use another beep box or How can I have access the existing beep file ? I meant to say, how can I edit the .wav file ? Please write me in detail. It would be very helpful for me. You can email me : ra75763@uge.edu
Thanks. Waiting for your response.
Google is your friend. Check on internet.^^
Free sound or other search.
Thibaut
Thibaut
