Hello there,
I have an EEG signal whose amplitude is normalized between -1 to +1 within each epoch.
There are 256 samples within an epoch.
Each epoch (256 samples) is an input to AutoRegressive box of order 5.
I am getting following auto-regressive coefficients for a single epoch:
1,-4.78718,9.30318,-9.17654,4.59432,-0.933777
The value of these coefficients seem to be large and as I increase the "order" it gets larger.
When I make the order = 15, the coefficients have values in the range of 1000.
Are such high value of AR coefficients expected for a normalized signal?
Or I am doing something wrong?
Edit:
I am working on OpenVibe version 2.2.0
Regards,
openvibeexplorer.
AutoRegressive Coefficients - Seem to be large for a normalized signal
Re: AutoRegressive Coefficients - Seem to be large for a normalized signal
Just to conclude:
I wrote a python script to invoke python module of AR coefficients. And it gives similar results as OpenVibe's AR coefficients.
Which confirms the correct functioning of OV AR coefficients module.
Thanks!
openvibeexplorer.
Thanks!
openvibeexplorer.
