OpenViBE forum
The OpenViBE community
It is currently Tue Nov 12, 2019 11:23 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Mon Mar 18, 2019 5:26 am
Offline
Hi all,
I want to use VRPN send data to ROS. I use the command as follows on linux.
g++ vrpn-receiver.cpp -o vrpn-receiver -I ~/openvibe-2.2.0-src/dependencies/include -L ~/openvibe-2.2.0-src/dependencies/lib
Here vrpn-receiver.cpp is the example code from openvibe. -I/path to include the .h file and -L/path to contains the library files. But the results as below.
/tmp/ccWHf056.o: In function `main':
vrpn-receiver.cpp:(.text+0x20c): undefined reference to `vrpn_Button_Remote::vrpn_Button_Remote(char const*, vrpn_Connection*)'
vrpn-receiver.cpp:(.text+0x251): undefined reference to `vrpn_Analog_Remote::vrpn_Analog_Remote(char const*, vrpn_Connection*)'
collect2: error: ld returned 1 exit status
Does anyone know how to fix the problems. Thanks.
Xiaofei
Top
 Profile
PostPosted: Fri Oct 18, 2019 6:31 pm
Offline
I am also experiencing the same issue. Have you found a solution?
Top
 Profile
PostPosted: Sat Oct 19, 2019 1:11 pm
Offline
Same problem here... I'm stuck and nobody else in the team has found a solution either! Plus, I'm the only one who more or less can handle OpenVibe in said team, and I'm too busy with my real life job these days (classifying these Jurmala apartments by rentability doesn't help designing mind-controlled games, quite the contrary), we'll be stuck for a while if I have to solve the issue by myself :cry:
Top
 Profile
PostPosted: Tue Oct 22, 2019 1:53 pm
Offline
Sorry same answer as fisherconanan.
Hum, check the code of the
Code:
CBoxAlgorithmVRPNButtonClient
that uses the VRPN.. Or The demo applications. Sorry I don't use vrpn yet. And this tutorial is for a very old version of OpenViBE.
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
