OpenViBE forum
The OpenViBE community
It is currently Fri Feb 21, 2020 12:30 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: LSL export (Gipsa)
PostPosted: Fri Aug 16, 2019 8:40 pm
Offline
Hi,
I tried to send out signals from Open-vibe Designer to Python for Data Analysis using Pylsl.
But I got "The stream named 'OpenViBE Stream' could not be recovered automatically if its provider crashed because it does not specify a unique data source ID."
I am not sure how to use the LSL export(Gipsa) box.
Many thanks,
Harvey
Top
 Profile
 Post subject: Re: LSL export (Gipsa)
PostPosted: Mon Aug 19, 2019 1:06 pm
Offline
Hi,
I have not yet had the time to look at the LSL protocol or how it is relayed to OpenViBE. You can see directly in the source code if you are used to the LSL protocol you should understand what is sent.
Thibaut
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
