Hi all
I read a tutorial about Implementing a signal processing box in OpenVibe
here http://openvibe.inria.fr/tutorial-1-imp ... ssing-box/
I done all step by step but i can't see my box in opevibe main page.
Do you think what's wrong
Problem in makeing a Box
- Attachments
- box3.jpg (56.31 KiB) Viewed 11288 times
- box2.jpg (196.12 KiB) Viewed 11288 times
- box.jpg (224.41 KiB) Viewed 11288 times
Re: Problem in makeing a Box
Hi Hamed,
when you launch Designer, do you see +1 plugin added from the .dll you're compiling your component into? The OV 1.3.0 says out of the box,
you should see 16 (and the path *should* be different as you're building yourself). If not, either your plugin is not compiled into the .dll or Designer is not loading the correct dll.
- Does your box have a unique name? (try writing part of it in the search slot in designer, top right)
- Does your box have a unique 64 bit identifier? no two box should have the same id.
Both of these are defined in the .h file of the box.
Cheels,
Jussi
Code: Select all
[ INF ] Added 15 plugin object descriptor(s) from [C:/Program Files (x86)/openvibe//bin/openvibe-plugins-contrib-signal-processing.dll]
Cheels,
Jussi
Dear jtlindgren
Thanks a lot for your reply
Do you think i include and declare in right line ?
If you made a Box in Openvibe could you please send a screenshot from your ovp_main.cpp file
- Attachments
- a1.jpg (110.92 KiB) Viewed 11276 times
- a2.jpg (124.6 KiB) Viewed 11276 times
- a3.jpg (139.74 KiB) Viewed 11276 times
- Attachments
- a4.jpg (120.01 KiB) Viewed 11276 times
- a5.jpg (68.6 KiB) Viewed 11276 times
Oops, didn't notice the message earlier. Basically you'll see many such ovp_main.cpp / .h files amidst the openvibe source code, every .dll is provided one, so there should be plenty of examples.
Best,
Jussi
Best,
Jussi
