Electrode vs. channel
Perdu
Post by Perdu »
I'm considering the list of devices posted previously on this forum, and I'm wondering whether there is a difference between electrodes and what's called "channels" (I can't figure out what it is exactly). On the previous list, the openEEG device is presented as having only 2 channels, whereas on the linked resource, it is advised to buy 5 electrodes. So, as the post is a-year-and-a-half old, I am considering the possibility that openEEG has been greatly improved since then! Is it the case, or are electrode and channels two different things?
I haven't found the information on this forum with a quick research, so I thought it was worth creating a thread about it.
Perdu - a student considering to experiment BCI
fabien.lotte
Re: Electrode vs. channel
Post by fabien.lotte »
Dear Perdu,
In case of what is called a monopolar montage, channels and electrodes are the same thing: each electrode gives you one signal. But it can be different if you use a different electrode montage, e.g., a bipolar montage. In such a montage, the signal you get is the difference between two electrodes. As such, you have one bipolar channel from 2 electrodes. You also need a ground electrode for EEG experiments. I don't know the OpenEEG system, but if it provides 2 bipolar channels, then you indeed need 5 electrodes : 2 electrodes for each of the 2 bipolar montages plus 1 ground electrode. I hope this helps,
Fabien
Perdu
Post by Perdu »
Thanks for your answer, I understand better now!
Perdu
