neuromarketing how and what eeg?
dakanadaka
Post by dakanadaka »
Hello there,
I'm still under research how to setup neuromarketing with EEG.
So the setup is simple:
Showing many ads in front of people and get all possible reactions from them,
like with eeg, and maybe more other things... with fMRI I wouldn't start because it is not cheap to buy :)
so the question is:
what EEG should I buy or any other info... budget is till 1000 euro for start,
if we see the good results then it can go even more.
kind regards
Re: neuromarketing how and what eeg?
Hi Daka,
NeuroMarketing might have its special needs depending on the localization of cravings inside the cranium. Perhaps some other people have some specific thoughts on this -- as an engineer, I can just point you to the OpenViBE office's reply to the general question,
http://openvibe.inria.fr/faq/#Which+EEG ... uld+I+buy?
Good luck,
