Hi my name is Ciaran
For my final year project I’m doing a BCI based project.
I am having MAJOR problems with downloading Epoc Simulink EEG importer. Every time I’m finished installing Epoc Simulink EEG importer I keep getting a message which says edk.dll was not found. For other programs like Emotiv Epoc and Emobot I’m having no such problems .
Epoc Simulink EEG Importer
Re: Epoc Simulink EEG Importer
To be more accurate "the procedure entry point EE_DataCreate could not be located in the dynamic link library edk.dll". I tried to reinstall as suggested but this does not work
You should be using the reasearch SDK !
