SSVEP detection problem
Posted: Tue Dec 18, 2018 10:08 am
Within the scope of my university studies we have build a one-channel EEG system based on OpenEEG work with the purpose of showing the students the capabilities of BCI. The device was tested using lab equipment and have shown that it is able to register the faint brain signals successfully. Then we started with experimental part. The set up is very basic, three electrodes are used to detect the EEG signals (Oz, A2 and FPz region). First bunch of experiments while testing the device were targeted on obtaining an Alpha wave and registering Alpha wave blocking by opening one's eyes. These experiments have shown very good results, demonstrating the signal amplitude and the frequency within normal range according to the studies.
As a next step the SSVEP detection was performed using OpenViBE software and default settings of SSVEP scenario (a shooting game). However, no SSVEP was detected in none of the experimental set ups. Power spectrum does not show the target frequency (8, 12, 25, 20Hz consequently tested) and no results are obtained. It seems like it just cannot register the SSVEP signals. It seems improbable while the Alpha wave detection is very successful.
I have searched through papers and could not find in any of it the reason why the SSVEP may not be registered on the first place (the closest I could get is what may influence the accuracy of the SSVEP, but in our case it is not helping). I'm desperate looking for an answer and will be very grateful if someone could advice what could be potential reasons for not being able to detect the SSVEP and realize the scenario.
I can provide any additional info on the matter if someone is willing to support.
Thank you very much!
