what is the difference between 'OVTK_GDF' and ‘OVTK_Simult’
liumutian
Post by liumutian »
what is the difference between 'OVTK_GDF' and ‘OVTK_Simultion’?
what does 'OVTK_....’ meanings?
Re: what is the difference between 'OVTK_GDF' and ‘OVTK_Simu
Hi, both are just names given to numeric codes. The ones with 'gdf' mentioned in them are likely corresponding to codes used by the gdf file format and adapted originally from there. The others are native to openvibe. OVTK is short for OpenViBE ToolKit.
liumutian
Post by liumutian »
jtlindgren wrote:Hi, both are just names given to numeric codes. The ones with 'gdf' mentioned in them are likely corresponding to codes used by the gdf file format and adapted originally from there. The others are native to openvibe. OVTK is short for OpenViBE ToolKit.
thanks
