problems with vrpn connection
amani
Post by amani »
Currently, I am using openvibe for motor imagery based brain machine interface. But I got a hard problem when using vrpn. Here is the details:
When I run the code to send the data from OpenVibe to VS2013, an error was accured.
For openvibe:
vrpn: Connection request received from 127.0.0.1: 127.0.0.1 23998
vrpn_Endpoint::connect_tcp_to: getprotobyname() failed.
vrpn_Endpoint::setup_new_connection: Can't write cookie.
vrpn_Connection_IP::handle_connection(): Can't set up new connection!
while for vs:
vrpn_poll_for_accept: getprotobyname() failed.
vrpn_Endpoint: mainloop: Can't poll for accept
vrpn_Connection::pack_message: Can't pack because the connection is broken
I followed the introduction of how to use vrpn on the website and I dont know what is wrong with my project.
I would appreciate it if anyone can help me. Thanks!
amani
Re: problems with vrpn connection
Post by amani »
Problem has been solved! I deleted the protocol file in C disk by mistaken.
Its surprising that the thing still launches and doesn't give a good warning message if something is missing.
But good to hear you got it sorted!
