Question about Independent Component Analysis
Posted: Fri Jun 30, 2017 4:42 pm
I try to use ICA to separate a linear combination of sine wave and square wave. I make to input channel one of them is sine+square, another is sine-square.I suppose the ICA can give me an sine wave and a square wave as result. However, after FastICA, I use signal display, and the output channels look exactly the same as input channels. How can I fix this issue?
