Hi all
I have a problem about sending data from OpenVibe to another software
How can i send value 1 from openvibe to 127.0.0.1 port 3000
I used OSC but OSC send another thing.
In VPRN i don't know how can i set 127.0.0.1 and 3000
Could you please help me
sending data
sending data
- vrpn.jpg (32.87 KiB) Viewed 4546 times
Re: sending data
Are you sure your receiving application is decoding correctly ?
You could also use OSC, and interpret this "other thing" as 1.
Re: sending data
I used UDP Test Tool for analyzing OSC output
one of this images is during OSC sending 1
- b1.jpg (237.27 KiB) Viewed 4542 times
- b2.jpg (244.46 KiB) Viewed 4542 times
Re: sending data
From what i see, this seems correct by OSC standard.
It use bundle command (23 62 75 6E 64 6C 65 00) followed by informations relative to the commands, things like command size (00 00 00 00 00 00 00 01 00 00 00 10).
Then we get an actual command (2F 61 2F 63 00 00 2C 69 00 00 00 00 01), sending integer (2C 69) to /a/c (2F 61 2F 63) with the value 1 (00 00 00 01).
Please check how you do osc decoding.
