OpenViBE 1.2.0 and vcomp120.dll
Some users have reported that running Designer in OV 1.2.0 causes errors about 'vcomp120.dll' missing, and subsequently some boxes are not available. The reasons seems to be that Visual Studio 2013 (x86) Redistributable has not been installed for some reason. It could be there is a bug in the installer. Nevertheless, after install, you may find the needed redist file as
C:\program files (x86)\openvibe\dependencies\arch\vcredist-2013_x86.exe
Running it from there should fix the problem while we investigate if there's something wrong with the installer. You can also obtain the redist directly from Microsoft for free.
Re: OpenViBE 1.2.0 and vcomp120.dll
I pushed out openvibe 1.2.0-1 which should fix this issue.
