I have a signal that I did the Fast Fourier Transform with OpenVibe, and I need pick this FFT signal to trainer my classificator. But, I don't know what the box I need to use. Then that I want pass this signal in a classificator and it return me for example if the signal is about the right hand.
Aline
Trainning a classificator
Re: Trainning a classificator
Hi Aline,
You might want to have a look at this scenario tutorial classification-0-training.xml in share/openvibe/scenarios/box-tutorials.
This will give you an example about how to use the classifier trainer.
Best regards
Best regards
