Will OpenVIBE work with Emotiv Insight without EEG, or does it need to be with EEG? I saw a post that it was compatible with the EPOC, but I haven't seen anything about the Insight. Also, what is the difference between the EEG version and the non-EEG? I tried asking the Emotiv forum already, and I've emailed, but I haven't gotten a response.
Any help will be greatly appreciated!!
-igreenberg
OpenVIBE with Emotiv Insight
Re: OpenVIBE with Emotiv Insight
Hi igreenberg,
in the OpenViBE Head Office(tm) we don't have an Emotiv Insight, so we can't make a definite claim this way or that. But
1) since the device channel characteristics are different from EPOC, and
2) since on the net I see a different SDK API for the Insight,
my guess would be that OpenViBE does not currently work with Emotiv Insight. If anybody has other info, let us know!
The difference between EEG and non-EEG versions is that with EEG version you get access to the raw data (the actual measurements). The "emotional states" etc that the non-EEG version gives you, are derived from this raw signal by some proprietary signal processing algorithms of Emotiv.
Cheers,
Jussi
Cheers,
Jussi
I have the same problem.
I think it may be a way to add Emotiv Insight to data acquisition server. By using Creating a new driver for the acquisition server.
Can anybody help me please.
