OpenViBE forum
The OpenViBE community
It is currently Mon Jan 27, 2020 3:49 pm
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Wed Jul 01, 2015 9:30 pm
Offline
Good day everybody,
I have recently downloaded OpenViBE to see how it can compliment some BCI research I am involved with. I am very new to OpenViBE but have worked through the video tutorials and messed around with some of the pre-loaded example environments. I have been trying unsuccessfully to temporarily store some data in OpenViBE. I am basically trying to do the following with a 16-channel EEG signal stream:
-Calculate the running RMS value of each channel in the signal stream
-Calculate the running average RMS value of all channels
-Display the average RMS values with the newly calculated ones from the incoming signal stream on a 2D graph (also a topographical map can be useful)
Is this possible with OpenViBE alone without having to stream the data to an external application? Any and all help is highly appreciated.
Regards
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
