I've tried to run P300-xDAWN scenairo, but when I started Acquisition step, I got this result. I don't know why. How can I fix this problem? Thank you!
[WARNING] At time 0.000 sec <Box algorithm::Generic stream writer> Compression flag not used yet, the file will be flagged uncompressed and stored as is
Generic stream writer in P300-xDAWN scenairo
Re: Generic stream writer in P300-xDAWN scenairo
Hi Duydubn,
this is not a problem. There is a setting called 'use compression' in many boxes, but the boxes do not actually implement any compression; it was probably planned that the boxes would support compression at some point but so far nobody has developed the feature. You can get rid of the warning by setting the use compression setting to 'false'.
Cheers,
Jussi
Cheers,
Jussi
