neurosky - 2D topographic map
Hello. I wanted to know - Is it possible to 2D topographic map and 3D topographic map with the device neurosky? I can not run these scripts.
Re: neurosky - 2D topographic map
I haven't tried because eye-candy aside, I'm not sure the result is very meaningful. But I imagine that by giving those boxes an
electrode configuration of just 1 electrode (in the tutorial scenarios they have more, using files in 'share/openvibe/electrode_sets/'),
it might work.
You can successfully run the corresponding tutorial scenarios with pre-recorded data, right?
it might work.
