Dear all..
Now i am trying to use Openvibe to store EEG signal from an experiment. The experiment is conducted by another software, so i want to synchronize the timing with OpenVibe. What i want to do is to use a Vrpn server in the experiment software to send stimulation as Button's state such that openvibe can receive them and mark the stimulation on the GDF recording or whatever file format it can be.
Since i need to send more than one stimulation, say, i need to send start recording, stop recording, stimulation onset etc..
But the Vrpn Button Client in openvibe can only receive one button's signal. How can i add the button number in the openvibe? Do i need to re-program the Button client in the openvibe?
Thank you.
Question abut Vrpn Client
Re: Question abut Vrpn Client
the VRPN Button Client can actually have multiple buttons. In order to add a new button you have to right click the box, choose modify outputs from the menu and then click on new.
Thank you very much... I found out that i can add button, but the GDF file writer only can take one stimulation inputs. How can i add multiple stimulations into that one box?jlegeny wrote:Hello,
You can combine several stimulation inputs by using Stimulation Multiplexer box. In the same way as with the VRPN Button, you can add as many entries as you wish. They will be merged into one stream.
-J
-J
Hi,,jlegeny wrote:You can combine several stimulation inputs by using Stimulation Multiplexer box. In the same way as with the VRPN Button, you can add as many entries as you wish. They will be merged into one stream.
-J
sorry to bother again...
Can u tell me where the Stimulation Multiplexer box is?
I can not find it in either download version or my complied version of Openvibe.. did i miss something in openvibe?
Wang Yubo
which version of OpenViBE are you using? The box itself is in Streaming -> Stimulation multiplexer.
In 0.13.0 we have introduced a search field which you can use to quickly find any box. You can press Ctrl+F as well to focus it instantly, it will filter the list of boxes and will display only the boxes that match the name.
