OpenViBE forum
The OpenViBE community
It is currently Sun May 26, 2013 7:17 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: Fri Apr 13, 2012 8:56 am
Offline
Hi,
I'm using OpenVibe to process the data from Emotiv EPOC headset.
For my research I need to extract the amplitudes of Alpha, Beta, etc... brainwaves with pre-defined frequency ranges.
I see 2 possible methods:
1. Apply FFT (with 0.16HZ pre-filtering + windowing) and extract the right spectra.
2. Apply a band-pass filter (e.g 16-24HZ for Beta waves) on the raw data.
Which method would be the best?
Thank you in advance
Alexei
Top
 Profile
PostPosted: Mon Apr 23, 2012 11:13 am
Offline
Both approaches would give rather similar performances, but the second-one may give slightly better results. I would suggest you have a look at the following papers who compared different approaches to extract band-power features for BCI:
Herman, Pawel, Prasad, Girijesh, McGinnity, Martin and Coyle, Damien (2008) Comparative analysis of spectral approaches to feature extraction for EEG-based motor imagery classification. IEEE transactions on neural systems and rehabilitation engineering: a publication of the IEEE Engineering in Medicine and Biology Society, 16 (4). pp. 317-26.
http://eprints.ulster.ac.uk/4141/
N. Brodu, F. Lotte, A. Lécuyer, "Comparative Study of Band-Power Extraction Techniques for Motor Imagery Classification", 2011 IEEE Symposium on Computational Intelligence, Cognitive Algorithms, Mind, and Brain (SSCI'2011 CCMB), pp. 1-6, 2011
http://hal.inria.fr/docs/00/60/91/61/PD ... _final.pdf
Top
 Profile
PostPosted: Mon Apr 23, 2012 2:29 pm
Offline
Thank you for your input!
I have one more qustion: I need to visualize the brand wave amplitudes in real time.
The visualization tools included into OpenVibe are quite limited.
Is there a way to export brain spectra to external graphical packages? If yes, how?
Thank you
ALexei
Top
 Profile
PostPosted: Tue Apr 24, 2012 8:02 am
Offline
The most common way to send data from OpenViBE to an external application would be to use VRPN (http://openvibe.inria.fr/vrpn-tutorial- ... plication/).
But this is a generic method, there is no dedicated connection to another graphical application.
Top
 Profile
PostPosted: Fri Apr 27, 2012 6:43 am
Offline
You could also try to use the matlab box and use matlab to plot the things you want to plot. Or if you do not have matlab, maybe there is a similar python box? Although I can not seem to find a python box, I definitely heard that someone developed that? Does anyone know the person who did?
EDIT: Ok stupid me, I found the python box after an update, it should be in the python directory inside the openvibe-plugins directory
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
cron
POWERED_BY
Translated by Maël Soucaze © 2009 phpBB.fr
