Problem with classifcation algorithm
toncho11
Post by toncho11 »
When I run the p300 bci scenario openvibe-scenarios\bci\p300-speller-xDAWN\p300-speller-3-train-classifier.xml
I get this error:
IBox& l_rStaticBoxContext=this->getStaticBoxContext();
	CIdentifier a;//we need to fill this
	CString b;
	l_rStaticBoxContext.getSettingValue(0, b);// b is filled here I suppose
	a=this->getTypeManager().getEnumerationEntryValueFromName(OVTK_TypeId_ClassificationAlgorithm, b);
	if(a==OV_UndefinedIdentifier) //true
		this->getLogManager() << LogLevel_Error << "Unknown classifier algorithm [" << b << "]\n"; // my code goes here!!!!!!!!!!!!!!!!!!!!!!
		return false;
This method:
uint64 CTypeManager::getEnumerationEntryValueFromName(
	const CIdentifier& rTypeIdentifier,
	const CString& rEntryName) const
returns a not found kind of value (0xffffffffffffffffll) for the algorithm.
I am not very much into these identificators, so I will appreciate some hints.
I am using the 13.1 code.
Also I have noticed this problem is only when the classifier is set to "LDA". When changed to "SVM" works fine.
I believe that LDA registration is missing in ovp_main.cpp project OpenViBE-plugins-classification-dynamic???
Anton Andreev
Gipsa-lab
p.s. I can not checkout the code from svn from svn://scm.gforge.inria.fr/svn/openvibe/trunk
jlegeny
Re: Problem with classifcation algorithm
Post by jlegeny »
I do not quite understand your problem. Have you created your own classification algorithm to use with the classification box? Could you be more precise about what are you trying to achieve?
As for the SVN, our servers have been upgraded and apparently there are some issues. For the time being the public access does not work.
Thank you
