Hi,
I have designed an amplifier-filter for eeg data acquisition and would be using NI USB 6009 data card. Would this be compatible with openvibe? Also i will be using single channel eeg data.
Aniket Deshpande.
OpenVibe newbie
Re: OpenVibe newbie
Hello Aniket Deshpande, and welcome on the forums!
First, sorry for the late reply.
To be compatible with openvibe, a new device must have its own driver.
A dedicated tutorial will help you implement such driver if you want to.
Hope this helps!
Laurent-
Hope this helps!
Laurent-
