Where can I find more information (book or any other sources) about the algorithm used in the video (for example the calculation for frenquency band power with the epoch)?
Algorithm used in the tutorial video???
Re: Algorithm used in the tutorial video???
Hi lapsaad,
Here is an article reviewing algorithms for classification of brain signals. The many references listed in this article could also be interesting for you.
"A review of classification algorithms for EEG-based brain–computer interfaces"
F Lotte, M Congedo, A Lécuyer, F Lamarche and B Arnaldi
Hope this helps
Hope this helps
Thank you Laurent for the information. I looked at the document and this can be a little introduction but only some algorithms are explained in detail.
I remain open to other sources of information particularly for the algorithm used in Neurofeedback.
thank you again,
lapsaad
thank you again,
lapsaad
