toncho11
Posts: 124 Joined: Tue Apr 19, 2011 7:58 pm
Post
by toncho11 » Tue Feb 21, 2012 8:29 am
I am exploring the tutorial about the new acquisition driver. Driver was automatically generated and placed where specified.
I have registered my driver in: ovasCAcquisitionServerGUI.cpp (header and vector)
Do I need to register the configuration "CConfigurationTestDriver"? This is what I missed last time.
boolean CDriverTestDriver::initialize(
const uint32 ui32SampleCountPerSentBlock,
IDriverCallback& rCallback)
assert(&m_rDriverContext!=NULL);//fails here
if(m_rDriverContext.isConnected()) return false; //actually here
if(!m_oHeader.isChannelCountSet()||!m_oHeader.isSamplingFrequencySet()) return false;
Currently my code fails with m_rDriverContext being NULL.
Please advise.
-Anton
lbonnet
Posts: 417 Joined: Wed Oct 07, 2009 12:11 pm
Post
by lbonnet » Tue Feb 21, 2012 6:11 pm
Hi Anton !
The only thing you need to use a new driver is registering it in the ovasCAcquisitionServerGUI.cpp file (#include and push_back in the vector), the configuration is not registered.
.. and if your driver is flagged as unstable, set AcquisitionServer_ShowUnstable to true in the config file.
I tried to assert the existence of m_rDriverContext too in a new empty driver, but couldn't reproduce what you are experiencing.
You didn't modify anything else, did you ?
Follow us on twitter >>
openvibebci
Checkout my (old) blog for some OpenViBE tips & tricks :
here !
toncho11
Post
by toncho11 » Wed Feb 22, 2012 6:58 pm
Hello Laurent,
I have another problem that might be the primary problem.
When I add the new driver files in the project file something goes wrong with the compilation.
Visual Studio can not find <gtk/gtk.h> all of a sudden in ovasCConfigurationBuilder.h
Do you use VS 2010?
Please try to add the files I have attached. Does it compile with them?
Without the new files everything compiles and runs as expected.
ovasCDriverTestDriver.zip
(3.95 KiB) Downloaded 213 times
lbonnet
Post
by lbonnet » Thu Feb 23, 2012 1:49 pm
Hello Anton,
Your source code works fine on my computer.
And seems very simple to me... no big deal except the assert part.
I use Visual Studio 2010.
Did you try cleaning the cmake cache and re-build from scratch the acquisition server ? (delete local-tmp/openvibe-application/acquisition-server)
openvibebci
here !
toncho11
Post
by toncho11 » Thu Feb 23, 2012 7:58 pm
I regenerated projects and reconfigured the acquisition server in VS.
I found the problem. It is:
m_vDriver.push_back(new CDriverTestDriver(m_pAcquisitionServer->getDriverContext()));
and not:
m_vDriver.push_back(new CDriverTestDriver(*m_pDriverContext)); //as in the tutorial
m_pDriverContext is NULL at that time
Please, change it
jlegeny
Posts: 239 Joined: Tue Nov 02, 2010 8:51 am
Post
by jlegeny » Fri Feb 24, 2012 9:20 am
Hello Anton,
indeed there was an error in the tutorial. Thank you for your input, it is corrected now.
