Problem with new box/algorithm
toncho11
Post by toncho11 »
I am working with the box from Tutorial 2: http://openvibe.inria.fr/tutorial-2-imp ... -in-boxes/
In ovp_main I have:
OVP_Declare_New(OpenViBEPlugins::SignalProcessing::CBoxAlgorithmSignalMaximumDesc)
It can not create the algorithm:
m_pMatrixMaximumAlgorithm=&this->getAlgorithmManager().getAlgorithm(this->getAlgorithmManager().createAlgorithm(OVP_ClassId_Algorithm_MatrixMaximum));
Method: IPluginObjectT* CPluginManager::createPluginObjectT
File: ovkCPluginManager
map < IPluginObjectDesc*, IPluginModule* >::const_iterator i;
	for(i=m_vPluginObjectDesc.begin(); i!=m_vPluginObjectDesc.end(); i++)
		if(i->first->getCreatedClass()==CIdentifier(l_ui64TargetClassIdentifier))
			l_pPluginObjectDesc=i->first;
	if(!l_pPluginObjectDesc)
		return NULL;
It goes into the return NULL and then crashes. It does not find l_ui64TargetClassIdentifier, but it should I suppose.
Any hints?
toncho11
Re: Problem with new box/algorithm
Post by toncho11 »
Problem turn-up to be easily fixable.
Algorithms are registered the same ways as Boxes are:
#include "ovpCAlgorithmMatrixMaximum.h"
OVP_Declare_New(OpenViBEPlugins::SignalProcessing::CAlgorithmMatrixMaximumDesc)
in ovp_main.cpp
The "OVP_Declare_New" macro adds both types to the list of available boxes and algorithms.
toncho11
Post by toncho11 »
Hi again,
Unfortunately I still can not complete Tutorial 2 - MatrixMaximum
I get an access violation invalid memory read in the following code in ovkCAlgorithm.cpp (line:365) when I click on "Play" scenario:
My source is here: http://adastra.googlecode.com/svn/trunk ... nalMaximum
It includes: the box and algorithm from Tutorial 2 and the test scenario.
This is the problematic part:
boolean CAlgorithm::process(void)
	__proxy_func_0__(process, "process callback", this->setAllOutputTriggers(false), this->setAllInputTriggers(false));
I have replaced __proxy_func_0__ macro with a real function call, but still I can not figure-out which object is corrupted and when this is happening in the workflow.
The log from Microsoft Application verifier http://www.microsoft.com/download/en/de ... x?id=20028
shows this:
First-chance exception at 0x73371ed7 in OpenViBE-designer-dynamic.exe: 0xC0000005: Access violation writing location 0x00000000.
<avrf:logEntry Time="2012-02-19 : 09:41:40" LayerName="Heaps" StopCode="0x13" Severity="Error">
  <avrf:message>First chance access violation for current stack trace.</avrf:message>
  <avrf:parameter1>0 - Invalid address causing the exception.</avrf:parameter1>
  <avrf:parameter2>73371ed7 - Code address executing the invalid access.</avrf:parameter2>
  <avrf:parameter3>d2e760 - Exception record.</avrf:parameter3>
  <avrf:parameter4>d2e7b0 - Context record.</avrf:parameter4>
  <avrf:stackTrace>
  <avrf:trace>vrfcore!VfCoreRedirectedStopMessage+81 (d:\avrf\source\base\avrf\avrf30\vrfcore\stopredirect.cpp @ 103)</avrf:trace>
  <avrf:trace>vfbasics!VerifierStopMessage+292 (d:\avrf\source\base\avrf\avrf30\providers\basics\basics.c @ 1214)</avrf:trace>
  <avrf:trace>vfbasics!AVrfpCheckFirstChanceException+c8 (d:\avrf\source\base\avrf\vrfcommon\support.c @ 1108)</avrf:trace>
  <avrf:trace>vfbasics!AVrfpVectoredExceptionHandler+16 (d:\avrf\source\base\avrf\vrfcommon\support.c @ 323)</avrf:trace>
  <avrf:trace>ntdll!RtlGetProcessHeaps+49d ( @ 0)</avrf:trace>
  <avrf:trace>ntdll!RtlCaptureContext+187 ( @ 0)</avrf:trace>
  <avrf:trace>ntdll!LdrRemoveLoadAsDataTable+c0b ( @ 0)</avrf:trace>
  <avrf:trace>ntdll!KiUserExceptionDispatcher+f ( @ 0)</avrf:trace>
  </avrf:stackTrace>
</avrf:logEntry>
Full log from Application Verifier is attached.
OpenViBE-designer-dynamic.exe.15.dat.zip
Full log from Application Verifier with the access violation error in the end.
(28.5 KiB) Downloaded 185 times
toncho11
Post by toncho11 »
I was able to load the debugging symbols for all required modules (dlls).
So problem turned up to be in:
void CStreamedMatrixDecoder::processChildData(const void* pBuffer, const EBML::uint64 ui64BufferSize)
where memcpy fails because destination is NULL.
Actually the problem is in the tutorial:
It says:
ip_pMatrixMaximumAlgorithm_Matrix->setDimensionCount(3);
but this contradicts with:
if( dimCount != 2)
	this->getLogManager() << LogLevel_Error << "The input matrix must have 2 dimensions";
	return false;
If I leave dimensions to 3 then the check above prevents the algorithm from doing any real work.
If I set dimensions to 2 then check is OK, but it terminates with the above error.
Which is the right way to code the tutorial?
lbonnet
Post by lbonnet »
Hi everyone !
The Tutorial has indeed a mistake.
Is totally irrelevant. This line should not be present... I added it to test the dimension verification in the Algorithm, and forgot to remove it when writing the tutorial on the website. My fault, sorry.
Indeed, happens to me also.
When you re-set the dimension count into a matrix, it gets re-initialized (buffer deleted, resized, etc.).
Simply delete the line:
if(m_oSignalDecoder.isHeaderReceived())
    if(!m_pMatrixMaximumAlgorithm->process(OVP_Algorithm_MatrixMaximum_InputTriggerId_Initialize))
        return false;
    m_oSignalEncoder.encodeHeader(0);
    l_rDynamicBoxContext.markOutputAsReadyToSend(0, l_rDynamicBoxContext.getInputChunkStartTime(0, i),
        l_rDynamicBoxContext.getInputChunkEndTime(0, i));
And it should be ok.
thank you for bringing this to our attention !
If you find another mistake in the tutorials or documentation, please tell us :)
toncho11
Post by toncho11 »
Hello Laurent,
Thank you for your feedback.
I removed:
What box do you use to visualize the output from SignalMaximum box? Is it a standard one - signal display?
These tutorials really help getting started with OpenVibe!
Anton
jlegeny
Post by jlegeny »
As long as the output of a box is of type "signal" and is not epoched (by a previous epoching box) you can display it by a signal display box.
