OpenVibe Visual Studio 2010 solution
Come here to discuss about OpenViBE in general!
Post Reply
toncho11
Post by toncho11 »
Based on openvibe-0.12.0-svn3107-src which is downloadable from OpenVibe site.
Unzip it to C:\Work\ to get: C:\Work\openvibe-0.12.0-svn3107-src
Install dependencies.
Build source.
Extract this zip: http://debian.fmi.uni-sofia.bg/~toncho/ ... lution.zip
in openvibe-0.12.0-svn3107-src\local-tmp\ replacing your previous Visual dir.
Note that I have kept my "CMakeLists.txt" in Visual folder.
Open Project.sln.
Building is not possible, but at least I now have VS 2010 as an IDE.
Hope this helps.
yrenard
Site Admin
Contact:
Re: OpenVibe Visual Studio 2010 solution
Post by yrenard »
Dear anton,
why don't you use the provided win32-generate-vc-proj.cmd script ?
Regards,
Yann
toncho11
Post by toncho11 »
Because it did not work for me:
see: viewtopic.php?f=4&t=494
This is if someone else is having the same problem.
yrenard
Site Admin
Contact:
Post by yrenard »
Could you try with latest SVN revision ? I saw a recent commit from Laurent Bonnet that should fix this problem !
Regards,
Yann
lbonnet
Site Admin
Post by lbonnet »
Indeed I just committed a modification of the script that generates the visual studio project.
It worked for me on win7 64b & VS 2010.
Tell me if it's ok for you.
Laurent
toncho11
Post by toncho11 »
Yes, it works with VS 2010 now.
Some of the projects seems to compile within VS 2010.
lbonnet
Site Admin
Post by lbonnet »
Ok good :)
We can't really compile all openvibe within Visual Studio because the build process needs to set up the environment before (the win32-init_env script).
If you want to be able to launch the build from VS anyway, here is a quick howto that you may find interesting.
BR
Laurent
toncho11
Post by toncho11 »
Hi,
I have created a small program that configures OpenVibe Designer and Acquisition server for me in Visual Studio 2010. It enables everything I need: compilation, execution and debugging. We could say that now it "really" compiles :)
blog post: http://debian.fmi.uni-sofia.bg/~toncho/ ... tudio.html
src: http://code.google.com/p/adastra/source ... stOpenVibe
Post Reply
