Can someone explain , what is exactly a stream matrix?
and how it differs from a normal signal,
and how to convert between the two?
Can someone explain , what is exactly stream matrix?
Re: Can someone explain , what is exactly stream matrix?
Hi Tsur and welcome on board,
A streamed matrix is basically a generic n-dimensional matrix, with possibly labels on these dimensions.
The stream "Signal" is a streamed matrix with some constraints : 2 dimensions (channels x samples), plus a sampling frequency.
You can find more information about openvibe streams on the dedicated page.
Hello Laurent ,
Thanks , this is the page I was looking for.
