digital readout of wave frequencies
realvalue
Post by realvalue »
I would like to use input from Neurosky Mindwave, and use Openvibe to output the changing mean frequencies and amplitudes, in real time. In Openvibe designer, I have worked through the tutorials, and attempted scenarios using Sinus oscillator (I will change it later into mindwave input) and attached univariate statistics and signal average. I have not been able to display the digital output Unfortunately, I am not a programmer, and I have not seen this scenario in the tutorials. Can you be of help? Thanks so much
Re: digital readout of wave frequencies
Dear realvalue,
I suggest you look at the box tutorials in share/openvibe-scenarios/box-tutorials ; you'll most likely find what you want.
